Wj-input-number or mask put on icon in the text
Posted by: kun.leeing on 29 May 2020, 5:53 am EST
    Posted 29 May 2020, 5:53 am EST
    Hi team,
    I am just wanting to ask if it is possible to show a icon before the text in the wj-input-*. For example, when the number user typed hit the limitation, it could show a warning icon ahead of the input number and when the number input is in normal scope, the icon disappear.
    I tried to use wjinputcontrol.inputElement.outerHTML or innerHTML, but it does not look like the right way. And advice?
  • Posted 1 June 2020, 1:22 am EST
    Hi Kun,
    You cannot add a warning icon directly into input mask. You will need to add the icon in the HTML template only and change its display accordingly.
    https://stackblitz.com/edit/ckkyne-wtwetj
  • Posted 1 June 2020, 10:47 pm EST
    Thanks, Ashwin. so basically, it is impossible to make the icon at the corner of the input textbox or merge it to the input control I guess?
  • Posted 2 June 2020, 2:25 am EST
    Sorry Ken, but that is not possible. I would suggest you add a single icon for all the warnings and update the visibility of the icons accordingly.
  • Posted 4 June 2020, 10:32 pm EST
    No worries. Thanks, ashwin. It is good enough. Just out of curiousity. :slight_smile:
