Wj-linear-gauge: valueChanged only when I release the mouse
Posted by: lucas.gagneten on 27 March 2019, 8:50 am EST
    Posted 27 March 2019, 8:50 am EST
    Hello.
    I have a Linear Gauge whose value can be modified with the mouse, implemented in Angular:
    <wj-linear-gauge  [(value)]="dataDensity"
                                    (valueChanged)="onDataDensityChanged()"
                                    [origin]="0"
                                    [min]="1"
                                    [max]="10"
                                    [step]="1"
                                    [isReadOnly]="false"
                                    [thickness]=".1"
                                    [thumbSize]="25"
                                    [showText]="'Value'"
                                    [showRanges]="false"
                                    placement="top">
      </wj-linear-gauge>
    Suppose I move the thumb from 1 to 10 with the mouse: The function “onDataDensityChanged()” is called several times, If I use the “valueChanged” event.
    I want to call (or run) the function “onDataDensityChanged()” only when I release the mouse, so the function is run only once.
    How could I do that? Maybe using the property “isTouching” (I don’t know how to use it)?
  • Posted 28 March 2019, 9:33 am EST
    You may simply handle the native mouseup event and perform the required action. Please refer to the following sample demonstrating the same and let us know if you face any issues:
    https://stackblitz.com/edit/angular-wcmhaj?file=src%2Fapp%2Fapp.component.ts
    ~Sharad
  • Posted 6 May 2019, 2:58 pm EST
    Thanks!
