WjPopup with owner position
Posted by: dharee.almario on 27 June 2025, 3:03 am EST
  • Posted 27 June 2025, 3:03 am EST
    I was trying to use the wjpop with owner as a tooltip. it has a property of position. I tried in from the demo link below it’s not working for angular. it only works on the javascript sample. Do you have any ideas how to make it work in angular?
    https://developer.mescius.com/wijmo/demos/Input/Popup/PopupsWithOwnerElements/angular
  • Posted 27 June 2025, 6:12 am EST
    It seems like an unexpected behavior for the Popup control, so we have forwarded this issue to the engineering team for further investigation with internal tracking ID - WJM-36625. We will update you when we have an update from the engineering team on the same.
    For now, as a workaround, you can handle the ‘initialized’ event of the Popup to set the ‘position’ property. Please refer to the following sample demonstrating the same - https://jscodemine.mescius.io/share/4q7P6ckLTUmNT25RssnoNQ/
