Adding detail lines
Posted by: darrell.bignell on 13 May 2020, 2:06 am EST
    Posted 13 May 2020, 2:06 am EST
    How do you repeat detail lines in a flexreport when you are using and object as a datasource. can assign values to all fields in the detail line but do not know how to add more than one detail line.
  • Posted 14 May 2020, 3:54 am EST
    Hi Darrell,
    I have created a sample report file that I have bind to the list of object to iterate the detail section, please have a look into the sample.
    I hope it helps. In case if you face any issue then please modify the attached sample accordingly.
    FlexReportDataSourceDemo.zip
