Posted 8 October 2020, 6:37 am EST
I desperately need your help with BarCode 128. For 2 months we are struggeling to make BarCode128 for AustrianPost, but their test maschine reject it. We didn’t get much information. All we have is these three documents attached (“ISO Spec - S10-12.pdf”, “BarCode Dimension - Produktionsnorm für Selbsthersteller bemaßt 2013.pdf”, “BarCode Specification - Page 9 - Barcodefibel 2013 Reco Barcode 13stellig.pdf”). We use Code128Auto.
Can you please take a look at the files and answer to these questions:
- Does ComponentOne BarCodeGenerator can gerenrate BarCode as they mentioned it below:
“Please deliver a barcode 128 (Code 128 symbology, defined in ISO/IEC 15417) with print quality of symbols, assessed in accordance with ISO/IEC 15416[10], be at least 2,6/A/630 and 2,6/A/660, where A is the aperture determined in accordance with ISO/IEC 15416 Table 1.
This requirement corresponds to the UPU standard S10 (identification of mail pieces - 13-digit identification) - see attached PDF, point 5. (ISO Spec - S10-12.pdf)” - What properties and what size should these barcodes have so it satisfies test mascihne (result of their tests are also attached “TestResults.txt”)
Thank You.
HrvojeBarCode128Auto.zip
