Binding C1FlexGrid to a Data Source From EF6
Posted by: castingdouala on 4 May 2018, 8:35 am EST
    Posted 4 May 2018, 8:35 am EST
    Hello Team,
    I have a database of more than 100000 Customers, each customer having a corresponding Orders. I wish to display this information as a treeview/hierachical (With search, filter and sorting). I have read the samples but i could not find it useful as my data is fecthed using EF6.
    Any Help on how to tackle this? Thanks.
  • Posted 4 May 2018, 8:47 am EST
    I forgot to say i use and Database first approach. If it helps…
  • Posted 7 May 2018, 9:34 am EST
    Just to confirm did you see the product sample Orders-EF-WinForms? Though it uses general DataGridView, you should still be able to get some help from it.
    Ruchir
  • Posted 7 May 2018, 10:03 am EST
    Hello Ruchir,
    No. Can i have a sample?
  • Posted 9 May 2018, 9:41 am EST
    You find C1DataSource related samples installed at \Documents\ComponentOne Samples\WinForms\C1DataSource\CS. Also, the sample I am referring to shows how to use C1DataSource along with DataGridView and should help you get along with using C1DataSource.
  • Posted 10 May 2018, 9:11 pm EST
    Hello I’m also working with EF6 and am trying to load into a flexgrid with predefined columns. Will loading from an IQueryable result work with a C1FlexGrid or does it require a DataGridView?
    This isn’t working for me:
    Dim pats = From p In context.Patients Select New PatientGridFields With {.PatientID = p.Id, .FullName = p.LastName & ", " & p.FirstName, .MRN = p.MRN, .Gender = p.Gender}
    PatientGrid.DataSource = pats
  • Posted 11 May 2018, 5:15 am EST
    I doubt, for binding C1Flexgrid to EF6 in code, please refer to the product sample TutorialsWinForms-C1FlexGrid (installed at \Documents\ComponentOne Samples\WinForms\C1DataSource\CS )and navigate to its ‘DataSources in Code’ part to see how that works.
    Ruchir
  • Posted 16 May 2018, 7:59 pm EST
    Thanks I was using public fields rather than properties, so the columns weren’t loading.
    I’m not sure if there’s a preferred way to load into a grid with existing columns, but I wrote a VB function for that:
        Public Sub LoadFlexGrid(ByVal grid As C1FlexGrid, ByVal list As IEnumerable, Optional useExistingColumns As Boolean = True)
            Dim initProps As Boolean
            Dim colProps() As System.Reflection.PropertyInfo
            Dim curRow As Row
            If grid Is Nothing Or list Is Nothing Then
                Exit Sub
            End If
            If Not useExistingColumns Then
                grid.DataSource = list
                Exit Sub
            End If
            grid.Redraw = False
            grid.Rows.Count = 1
            For Each item In list
                If Not initProps Then
                    ReDim colProps(0 To grid.Cols.Count - 1)
                    For j = 0 To grid.Cols.Count - 1
                        colProps(j) = item.GetType.GetProperty(grid.Cols(j).Name, System.Reflection.BindingFlags.Public Or System.Reflection.BindingFlags.Instance Or System.Reflection.BindingFlags.IgnoreCase)
                    Next
                    initProps = True
                End If
                curRow = grid.Rows.Add
                    If colProps(j) IsNot Nothing Then
                        curRow(j) = colProps(j).GetValue(item)
                    End If
                Next
            Next
            grid.Redraw = True
        End Sub
  • Posted 17 May 2018, 12:34 am EST
    Thank you for sharing the cause of the trouble for you and it’s resolution. I hope your solution will help others in the community.
    Ruchir
