Bound TrueDBGrid loses values depending on the RowColChange event behaviour
Posted by: oriol on 3 October 2017, 5:43 am EST
    Posted 3 October 2017, 5:43 am EST
    We have been experiencing problems lately with the build 4.0.20172.217 of the TrueDBGrid.
    Note that this happens to us when we bind the grid to a DataSet (I haven’t tested it with an unbound grid).
    If we try to retrieve some values in the RowColChange event, full column values disappear.
    We noticed that it happens on 2 different case scenarios.
    Hopefully the test that I attach will be useful to reproduce the problem.
    You’ll see that there are two grids (an ‘employees’ grid and a ‘departments’ grid). If you navigate through the employees, the second grid will show each one’s departments. Also, there’s a button that clears and refills the employees grid.
    PROBLEM 1:
    • Press the “Empty the employees grid” button
    • Repress the button to fill it again
    • The employees grid loses the ‘Code’ value
    PROBLEM 2:
    • Select the second row on the departments grid (‘2’-‘Support’)
    • Select the second row on the employees grid (‘2’-‘Joe’)
    • Select the first row on the employees grid (‘1’-‘John’)
    • The departments grid loses the ‘Code’ value
    We’ll be willingly waiting for your reply, thank you very much.
  • Posted 3 October 2017, 6:01 am EST
    I’m sorry but I’m trying to upload the test sample and it won’t let me.
    It’s a 0.8 MB zip file and it says “You can’t upload files of this type.”
    Am I missing something?
  • Posted 4 October 2017, 3:12 am EST
    Sorry for inconvenience caused. The Zip file must have ‘.zip’ extension. Kindly try to upload the zip file with “.zip” extension.
  • Posted 4 October 2017, 7:39 am EST
    Attached is the sample project
  • Posted 5 October 2017, 2:30 am EST
    We could not see any attached sample project here. Could you please attach the sample again.
  • Posted 5 October 2017, 3:36 am EST
    Attached againC1Test.zip
  • Posted 5 October 2017, 5:04 am EST
    For Problem1:
    Use the “C1TrueDBGrid1.Splits(0).Rows.Count” instead of “C1TrueDBGrid1.RowCount”, as “RowCount” is supposed to be used for unbound grid.
    For Problem2:
    We are analyzing the root cause which the issue. However, there is small workaround to overcome the problem.
    Set “Row” property of department grid to 0 in “RowColChange” event.
    Please refer the attached modified sample. Hope it helps.
    C1Test_Modified.zip
  • Posted 4 December 2017, 5:45 am EST
    Hi!
    The issue has been escalated to the development team, and we will inform you once it is fixed [Tracking Id : 299040]. Meanwhile, you can find the attached sample useful as workaround.
    Meenakshi
    Prj_BoundGrid.zip
  • Posted 25 January 2018, 12:10 am EST
    Hello!
    The bound grid issue has been fixed in our latest hotfix, that can be downloaded from here :
    http://prerelease.componentone.com/hotfixes/dotnet/C1WinForms.4_4.0.20173.291.zip
    Best regards,
    Meenakshi
