Bug: MouseWheel in WinForms C1ComboBox
Posted by: andreas.kren on 18 September 2017, 9:12 am EST
    Posted 18 September 2017, 9:12 am EST
    the mouse wheel in drop down portion of a c1ComBox is only working when the drop down area gets the focus.
    It s not working when the scroll bars are clicked, I get it only to work when the mouse is somewhere over the drop down area and then I press the middle mouse button (on the wheel in my case) AND I move the wheel up. Since then the wheel is working flawlessly. (unless you close the dropdown and open it again)
    Cant’t be the original intention ?!
    Regards.
  • Posted 20 September 2017, 5:38 am EST
    Hi Andreas,
    I am able to reproduce the issue at my end as well. I have escalated this to the development team (ID: 286907) and will revert you back once have any information from them.
    Pragati
  • Posted 22 September 2017, 12:04 pm EST
    Thank you. Maybe there is a workaround for the meantime?! Sth one (=I) could do in DropDown Event ?
  • Posted 28 September 2017, 12:53 am EST
    Hi Andreas,
    I am sorry but there is no workaround as of now.
    However, the fix for this issue will be available in 2017 v3 release.
    Pragati
  • Posted 14 November 2017, 6:41 am EST
    Hi!
    The issue has been fixed in the latest build of 2017 V3. And, you can update using C1Live.
    Meenakshi
  • Posted 30 January 2018, 2:28 pm EST
    Just to follow-up, did you upgrade using C1Live. If you haven’t then you can also use the following build version for the same: http://prerelease.componentone.com/hotfixes/dotnet/C1WinForms.4_4.0.20173.291.zip
    Do let me know, if you still face the issue.
    Ruchir Agarwal
