Posted 6 April 2022, 1:22 am EST
Hi Christian,
Could you please let us know the exact version of C1 Controls you were using before testing the versions 2021v3 (532) and 2022v1 (548)?
FYI, After the 2020v2 release, we have updated our licensing model. The previous model used a licenses.licx file to license an application. But the new licensing model uses a runtime license ([Application_Name].gclicx file) as an embedded resource in your application to properly license the application.
If you were using a version older than the 2020v2 release, then the issue you are facing might be observed when you use the newer version of C1 controls without the embedded runtime license, which results in a popup form showing that your application is not licensed. Since you are using the C1 controls in a Windows Service Application, the application is not allowed to show any UI popups resulting in the exception you have mentioned. If you are upgrading from a version older than the 2020v2 release, we suggest you embed the runtime license in your service application and see if the issue still persists.
Please refer to the link below for steps to generate a runtime license.
https://www.grapecity.com/componentone/docs/license/online-license/create-runtime-license.html
Also, if you are using a class library in your application with an older version of controls, you will need to follow some extra steps to generate runtime licenses for these class libraries as well. Please refer to the link below showing these steps in detail.
https://www.grapecity.com/componentone/docs/license/online-license/license-user-controls.html
Kind Regards,
