Posted 14 December 2018, 2:11 am EST
You can use the DesignerApp sample of FlexReport, located at: [i]Documents\ComponentOne Samples\WinForms\C1FlexReport\CS[/i]
This sample includes the actual source code of the C1FlexReport Designer application that is shipped in binary form with ComponentOne Studio for WinForms (with some minor differences - e.g. the “check for updates” functionality is excluded). In addition to the C1FlexReport component, the application uses several other ComponentOne WinForms controls and components, including the C1FlexReportDesigner control included in the C1.Win.FlexReportDesigner.4 assembly. (That control may be used by itself too, but it should be noted that its interface is subject to change without notice - if you do use it, make sure
to carefully check the “breaking changes” entries in the ChangeLog.html when
updating to a new version of ComponentOne Studio.)
