C1 excel evaluation version popup when using new flexgrid 4.5.2 dlls
Posted by: hrvoje.zirdum on 5 November 2019, 7:55 am EST
    Posted 5 November 2019, 7:55 am EST - Updated 4 October 2022, 12:32 am EST
    C1 Excel Trial Popup when using new Flexgrid 4.5.2 DLLs
    I have a WinForms subscription that expires in January 2020. I’ve updated C1WinForms to the new 20192.1.375 release, which includes version 4.5.2 DLLs.
    I changed all DLL sin my app to 4.5.2. Everything works fine except the flexgrids SaveExcel method.
    When I use C1Flexgrid and ImportExport DLL version 4.5.2. then SaveExcel method displays a pop-up window for C1Excel stating that it is an evaluation version.
    When I use C1Flexgrid and ImportExport DLL Version 4, everything works fine = no popup.
    I have an example and a picture attached that shows everything I’ve written.
    Can you help me to avoid this problem so I can change all DLLs to version 4.5.2 and create a new production version for my app?
    Hrvoje
    WindowsFormsAppGridExportTest.zip
  • Posted 6 November 2019, 1:43 am EST
    Hello Hrvoje,
    Thank you for attaching the image and the application.
    This is a known issue and the team is working over to fix it. I will update you once the issue gets fixed.
    Meanwhile, to resolve the issue for you with the current version, I would suggest you add the following entry in your project’s licenses file.```
    C1.C1Excel.C1XLBook, C1.C1Excel.4.5.2
    Ruchir
  • Posted 6 November 2019, 3:41 am EST - Updated 4 October 2022, 12:32 am EST
    Thank You. Now it works.
    Can You please tell me when the new Ribbon will be in Release phase?
    Now it is in Beta phase and I can not use it in my app. I randomly get popup windows stating that. I attached picture where you can see that.
    When we can expect 2019.v3?
    Thank You.
  • Posted 7 November 2019, 12:58 am EST
    The Ribbon will release in the upcoming 2019v3 release. ComponentOne 2019v3 release is planned for the end of November.
    Ruchir
  • Posted 7 November 2019, 3:38 am EST
    Thank You.
    Hrvoje
  • Posted 7 November 2019, 10:03 am EST
    Will the new ribbon be backwards compatible with the old one or will it require substantial changes in the code?
  • Posted 8 November 2019, 4:24 am EST
    Hi Mike,
    the new ribbon was discussed here: https://www.grapecity.com/forums/winforms-edition/questions-about-the-new-ri
    Hopefully this threads answers your question :wink:
  • Posted 8 November 2019, 4:38 am EST
    Hello Mike,
    The new Ribbon control is an enhancement of old Ribbon control, so most of the old features will be supported. Also, the new Ribbon will have a similar API with few changes. So, migrating the old component to the new Ribbon would not require substantial changes.
    For details, you can follow the thread Wolfgang mentioned.
    Ruchir
