C1 PrintDocument To FlexViewer
Posted by: hrvoje.zirdum on 26 April 2020, 11:55 am EST
    Posted 26 April 2020, 11:55 am EST
    I make my reports by using C1PrintDocument and I do everything through code. I want to start using flexviewer and here is the problem that I have. I attached simple report that I have to make. I solved it by using C1PrintDocument but I want to do it using flexviewer by coding it.
    Template for the report is in word file where I put:
    black text - text that exists by default in every report
    red color - text that comes from the database dependent from the process
    blue color - text that every user changes/adds before he/she clicks on button Print
    orange color - text where I made remarks and explanations
    So, can you please make an example (using this attached word) in FlexViewer but through code, like you do when using C1PrintDocument. With C1PrindDocument I could do everything.
    Thank You.
    Hrvoje
  • Posted 26 April 2020, 11:57 am EST
    I attached zip file.
    Note:
    I looked through help files and examples and I could not find how to do this attached example through code only.
    Thank You.
    Hrvoje
    Example.zip
  • Posted 27 April 2020, 7:58 am EST
    I have analyzed your document and I suggest you to use the C1PrintDocument instead of the FlexViewer. Also, C1PrinntDocument is not a legacy control. We still support the C1PrintDocument.
    From FlexViewer, I assume that you are supposed to say the “FlexReport”.
    Request to confirm if you need anything else.
  • Posted 27 April 2020, 8:17 am EST - Updated 3 October 2022, 11:53 pm EST
    I know that C1PrintDocument is not legacy control. My idea is to start using FlexReport and FlexViewer, but I need help how to do that with that example I provided - through code if possible.
    Is there a way to do that report using FlexReport but through code object model? I saw in help that it is possible to do everything through code, but I don’t see an example I can use.
    Thank You.
    Hrvoje
  • Posted 28 April 2020, 2:30 am EST
    I have created a demo sample to achieve your requirements. Could please refer the attached sample and create your own report as per the given sample.
  • Posted 28 April 2020, 2:31 am EST
  • Posted 28 April 2020, 2:48 am EST
    Thanks, but that can’t help me. We will stick to C1PrintDocument.
    Hrvoje
