C1.Win.C1List.C1Combo Vertical Alignment not working/possible
Posted by: jens.eidinger on 13 March 2020, 9:35 am EST
  • Posted 13 March 2020, 9:35 am EST
    we want to re-design our application, which uses C1Controls. In this way we also want to increase the size of C1Combo’s. We want the text to be vertical centerd, but I wasn’t able to vertical align the text content as I did it for C1ComboBoxes. I also tried for the C1Combo’s setting Style.VerticalAlignment to center, but without success. Is this a bug or can’t we set the VerticalAlignment for C1Combo controls?
    Best,
    Jens
  • Posted 16 March 2020, 2:59 am EST
    Hi Jens,
    The VerticalAlignment property is working as desired at our end, please find the attached sample for reference.
    If you are doing something else then please modify the sample accordingly replicating the issue.
    C1ComboVertcalAlignDemo.zip
  • Posted 16 March 2020, 3:27 am EST - Updated 3 October 2022, 11:34 pm EST
    Hi Prabhat,
    thanks for your reply.
    I left some details, sorry.
    Applying the following steps to your testcase and you will see my issue.
    C1Combo
    BorderStyle = None
    Size shrinks to Height = 15
    Height has to be 25
    set AutoSize = false
    increase height to 25
    → text is aligned top
    C1ComboBox
    BorderStyle = None
    Size shrinks to Height = 13
    Height has to be 25
    → works correct
    Best,
    Jens
  • Posted 17 March 2020, 1:08 am EST
    Hi Jens,
    We are discussing this with the developers and will let you know soon.
    [Internal Tracking ID: 426243]
  • Posted 27 May 2020, 5:35 am EST
    Hi Jens,
    Sorry, but as per the developers there is no way to set Horizontal Alignment for C1Combo, as the editor is a Microsoft TextBox that does not have this capabilities.
  • Posted 27 May 2020, 5:53 am EST - Updated 3 October 2022, 11:34 pm EST
    Hi Prabhat,
    thanks for your reply. But we don’t need a horizontal alignment, we need the vertical alignment. You said that the C1Combo has a TextBox as editor, when I use a TextBox the text will be automatically aligend vertical centered. Shouldn’t it be then also possible in the C1Combo?
    Best,
    Jens
  • Posted 28 May 2020, 4:52 am EST
    Hi Jens,
    We are getting in touch with the developers for the same and will get back to you with the updates soon.
  • Posted 29 October 2020, 10:28 am EST
    Hi Prabhat,
    are there any updates about this issue?
    Best,
    Jens
  • Posted 29 October 2020, 9:51 pm EST
    Hi Jens,
    We are getting in touch with the developers for the update and will let you know soon.
  • Posted 26 April 2023, 12:50 am EST
    Apologies for the delay in response.
    This issue has been fixed back in 2021V3 builds and ‘VerticalAlign’ property is added for vertical alignment of text in C1Combo’s Editor area.
    Please update your project with the latest builds to resolve this issue.
