C1.Win.Chart.FlexChart - changing data in series not rescaling y-axis
Posted by: richard.sadler on 15 July 2018, 6:56 am EST
    Posted 15 July 2018, 6:56 am EST
    I have a Flexchart for which I have 4 data series already added to (with no data). I load up the data series at run time (the user can select various sets of data to be displayed in the chart but I only allow a maximum of 4 to be selected at any time)
    if I load all the data up in say 2 of the data series when I first load the control up, data sizing works as expected. If I then start loading data in the other data series, the Y Axis doesn’t always re-scale.
    Is there a way I can force the re-scaling?
    thanks
    Richard
  • Posted 16 July 2018, 8:05 am EST
    Any chances that you have set the Axis Min/Max values? As by default FlexChart axes scale themselves according to data being plotted.But, if Min/Max values are set then they will prevent the axis scaling in the corresponding direction.For the axis to auto scale you need to set the Min/Max to their default values,i.e. double.NaN
    You can also refer to the attached sample for an example.
    Prj_LoadDataAtRun.zip
  • Posted 16 July 2018, 6:09 pm EST
    Yes, I was setting max and min values.
    thanks for your help
