C1.Win default to older version after updating to the latest version
Posted by: Ranba790 on 8 February 2022, 9:55 am EST
  • Posted 8 February 2022, 9:55 am EST
    After updating to version 4.5.20213.532, C1.Win when setup as Specific Version to false in the property window, will change to the previous version 4.5.20212.513.
    If using Specific Version =True, it works ok, in the same project I have C1.FlexGrid loaded with Specific version=False and it works ok
  • Posted 9 February 2022, 6:37 am EST
    According to past reports, this issue usually occurs when you have both WinForms and WPF edition installed on your system. When you set the specific version of the C1.Win reference to the false, visual studio sometimes resolves it to the C1.Win DLL located in the WPF folder. Starting from the 21v3 release, it has been removed from the WPF edition, you either update to the latest WPF version or add the C1.Win reference of the correct version explicitly.
    If you do not have the WPF edition installed in your system, then we would suggest you re-install the WinForms edition and let us know if the issue persists.
    Avnish
    addref.zip
  • Posted 9 February 2022, 9:12 am EST
    Thanks, that fixed the issue
    Ran
