C1CalcEngine vs C1ExpressionEditor
Posted by: gkayne on 18 September 2020, 3:13 am EST
  • Posted 18 September 2020, 3:13 am EST
    I have a typed list as a data source - can anyone help me understand the following inconsistencies:
    1. When is use the C1ExpressionEditor visually it recognizes all the property descriptor fields without issue using:
    • Direct properties work using the property name
    • Child properties work using the property name - you do not have to qualify the path (ie.ChildClassName.PropertyName)
    • Custom Properties added with delegates work using the added property name
    1. When using the C1CalcEngine against this source:
    • Child properties do not work using the property name - you have to qualify the path (ie.ChildClassName.PropertyName))
    • Custom Properties added with delegates are note recognized
    1. When I replace the C1CalcEngine object with a C1ExpressionEditor and use it in code (it is not displayed) – I run into the same issues as (2) above using the C1CalcEngine.
    I am trying to add a custom field to my typed list which assigns a delegate to a function that uses the C1CalcEngine to evaluate the formula entered by the user. It works with the restrictions shown in bullet 2 above.
    Is there a way to have the C1CalEngine work with field names in the same way the C1ExpressionEditor does when displayed?
    Why does C1ExpressionEditor evaluate fields differently when displayed vs using it in code without displaying it.
  • Posted 21 September 2020, 4:42 am EST
    So after looking at this more closely, it appears the C1CalcEngine is reading the properties in the underlying data associated with TypedList and not the properties added to the TypeList’s PropertyDescriptorCollection - so is ITypedList not supported by the C1CalcEngine.
  • Posted 22 September 2020, 3:06 pm EST
    Hello Glen,
    Would it be possible to share a stripped down application? It would help us in effectively investigating the concern.
    With thanks,
  • Posted 22 September 2020, 3:44 pm EST
    I’ll put an example together - but essentially it comes down to using a typed list as the datasource for the C1CalcEngine. It does not recognize the fields defined in the PropertyDescriptorCollection - it exposes the Public Properties of the underlying Type - which is not desired.
    If you use the same Typed List for the C1ExpressionEditor and display it, it recognizes and exposes the fields defined in the Type List’s PropertyDescriptorCollection as desired.
  • Posted 23 September 2020, 5:00 am EST
    A sample is attached . vbCalcEngineDemo.zip
  • Posted 23 September 2020, 1:29 pm EST
    Thank you for the demo, Glen. I understood your concern and can observe the behavior like you mentioned.
    I am discussing it with dev [ID: 465261] and will get back to you as soon as there is an update.
  • Posted 13 October 2020, 5:47 am EST
    Any update on this.
  • Posted 13 October 2020, 11:58 pm EST
    As per the latest information from team, C1CalcEngine uses C1DataCollcetion for work with data source and this library doesn’t support ITypedList. So, its an enhancement request and they have it in their to-do list.
    To help you with a update, I have requested for an ETA and will update you as soon as I receive it.
  • Posted 14 October 2020, 4:16 am EST
    The ETA of the feature is 2021v1 release.
    Ruchir
  • Posted 22 October 2020, 4:06 pm EST
    The team has confirmed about the current limitation and is working over it.
    Meanwhile, as workaround you can add Nuget packages ‘C1.DataCollection’ (.25 build) and ‘C1.DataCollection.BindingList’ (.25 build). Then, change the data source of CalcEngine (AsDataCollection from C1.DataCollection.BindingList) in MyDataCollection class, as follows:```
    Public Overridable ReadOnly Property CalcEngine As C1CalcEngine
    Get
    If _CalcEngine.DataSource Is Nothing Then
    _CalcEngine.DataSource = Me.AsDataCollection()
    '_CalcEngine.DataSource = LiveView
    End If
    Return _CalcEngine
    End Get
    End Property
  • Posted 28 October 2020, 4:55 am EST
    Thanks for the reply - I’ll try it out - I have a current work around where I pass a delegate to a C1ExpressionEditor and use it to evaluate the expression when the grid is displayed - but it is not a preferred solution.
    If by using CalcEngine.NET standard 2.0 you mean the next version to be released in the 2021v1 release, then yes. Can you please confirm this version is not currently available.
  • Posted 29 October 2020, 10:10 am EST
    Thank you for sharing the workaround you are using.
    Yes, thank you for confirming. Also, yes, the version is not yet available.
  • Posted 25 April 2021, 11:57 am EST
    This does not appear to have been updated in the 2021v1 release - can you please confirm that to be the case.
  • Posted 26 April 2021, 8:11 am EST
    We are getting in touch with the developers for the same and will let you know soon.
  • Posted 8 June 2021, 6:07 am EST
    Can I get an update.
