C1Chart Print Preview
Posted by: dan.seybold on 16 June 2020, 11:21 am EST
    Posted 16 June 2020, 11:21 am EST
    I was attempting to implement a print preview option for the end user with a C1Chart similar to the option for a print preview for a C1FlexGrid, but I was unable to find any information regarding this except for a couple lines in the “Key Features” stating that there were options for
    “Preview and print entire chart:
    Choose from various printing methods to fit your needs using the PrintChart method.”
    Which leads me to believe there is a way to do this.
  • Posted 17 June 2020, 12:32 am EST
    C1Chart doesn’t provide any built-in option for previewing the print. However, you might implement the Previewing functionality using MS PrintPreviewDialog if needed. Also, you may refer to the attached sample for various print/export functionalities supported by the C1Chart.
    Just in case, C1Chart is in maintenance mode now and FlexChart is our new and more efficient charting control. If there is no specific requirement to use C1Chart, I would suggest you to use FlexChart. You may get the sample project for printing in FlexChart from “https://www.grapecity.com/samples/flexchartprint” which also support previewing functionality.
    Basant
    PrintIt2D.zip
