C1Combo RowTracking
Posted by: r.trofymchuk on 7 December 2020, 11:38 am EST
    Posted 7 December 2020, 11:38 am EST
    I’m using C1.Win.C1List.C1Combo.
    If I place this element on a form through the form designer and set the property RowTracking=true, the program works correctly and the value in the open list is highlighted, but if I add this element on a form through the code and set the property RowTracking=true, the highlighting does not work anymore:
    private void Form1_Load(object sender, EventArgs e)
    C1.Win.C1List.C1Combo cd=new C1.Win.C1List.C1Combo();
    cd.RowTracking = true;
    this.Controls.Add(cd);
    DataTable dtCombo = new System.Data.DataTable();
            dtCombo.Columns.Add("Value");
                       for (int i = 0; i < 50000; i++)
                dtCombo.Rows.Add(i.ToString());
            cd.ColumnHeaders = false;
            cd.DataSource = dtCombo;
    What is the difference?
  • Posted 8 December 2020, 2:33 am EST
    Hi Mike,
    As per the developers, it’s an old limitation for this control, as a workaround: use BeginInit/EndInit methods.
    C1.Win.C1List.C1Combo cd = new C1.Win.C1List.C1Combo();
    cd.BeginInit();
    cd.EndInit();
