C1ComboBox: Clear Funtion return exception
Posted by: samo3889 on 19 December 2017, 6:15 am EST
    Posted 19 December 2017, 6:15 am EST
    Hi All,
    i use C1ComboBox
    when i do Clear function on C1ComoBox return exception
    look at the following attachment (C1ComboBox.png)
    Saleem
  • Posted 19 December 2017, 7:15 am EST
    I could not replicate the issue with latest build.
    http://prerelease.componentone.com/dotnet40/C1WinForms/2017-T3/C1WinForms.4_4.0.20173.286.zip
    Please check with the same build.
    If this does not solve your issue them share a sample application so that we can assist you further accordingly.
    Singh
  • Posted 19 December 2017, 8:45 am EST
    thank you Singh
    i found the problem
    the following line:
    this.cmbLoadFilterSort.DropDownStyle = (C1.Win.C1Input.DropDownStyle)System.Windows.Forms.ComboBoxStyle.DropDownList;
    This is what makes the problem
    but how i can clear all combobox values ?
    Saleem
  • Posted 20 December 2017, 12:03 am EST
    Please use the below suggestions:
    1. Clears all text from the textbox area of C1ComboBox.
    C1ComboBox1.TextDetached = True;
            C1ComboBox1.Clear();
    1. Clears all items from the C1ComboBox control.
    C1ComboBox1.Items.Clear();
    If you are using ItemsDataSource for items then assign it to null as:
    C1ComboBox1.ItemsDataSource = null;
    For more info see the documentation at http://help.grapecity.com/componentone/NetHelp/c1input/webframe.html#C1ComboBox%20Control%20Overview.html
    Hope, it will solve your issue.
    Singh
