C1DockingTab, adding and removing tabpages and controls in tabpages
Posted by: mysql.jorge on 17 May 2020, 5:49 pm EST
  • Posted 17 May 2020, 5:49 pm EST
    hi, help in two things
    1, when i use the right button, the control get’s out of the tabpage2, so far so good, but when i try to put it back with the left button it’s not working, what am i missing?
    2, the .remove and .add for the tabpage, to hide and enable it again, is the best way to do it?
    Please check the attached example,
    thanks in advanced,
    teste align textbox.zip
  • Posted 18 May 2020, 3:39 am EST
    1. Actually, the grid is placed on the tab page. You just have to position it correctly so that it is visible.
    2. Instead of removing the TabPage (which is not needed here), you can just hide it.
    Please see the attached sample for these changes.
    teste align textbox (Fixed).zip
    Jitender
  • Posted 18 May 2020, 4:24 am EST
    Thanks, it’s the tabvisible, I was trying .visible and that property takes no effect.
    Thanks!
