C1DockingTab not honoring presence of C1StatusBar
Posted by: Charles.Jimenez on 7 August 2025, 12:53 pm EST
    Posted 7 August 2025, 12:53 pm EST
    I have a form that includes C1DockingTab and C1StatusBar. When I set the C1DockingTab to Dock=Fill, it extends below the C1StatusBar area at the bottom of the form, to the full size of the form’s client area. I have searched both controls and cannot find any property in either control that affects this behavior?
    Is this configurable or is it a design flaw / bug in one of the controls?
    I am using Winforms .Net Framework 4.8 versions of the controls in a .Net Framework 4.8 project in Visual Studio 2022.
    Thank you,
    Charlie
  • Posted 8 August 2025, 3:12 am EST
    Hi Charlie,
    maybe it already helps if you right click the C1DockingTab and call “Bring to Front” from the context menu?
    If not: could you create a simple sample reproducing the problem and post it here?
  • Posted 8 August 2025, 7:01 am EST
    Hi Charlie,
    We agree with @Wolfgang’s assessment i.e. it appears that the C1DockingTab is positioned behind the C1StatusBar control. As a result, docking it to Fill causes part of it to be hidden behind the status bar.
    To resolve this, you can right-click on the C1DockingTab and select the “Bring to Front” option to move it in front of the C1StatusBar.
    We’ve attached a sample project demonstrating the correct behavior. If you’re experiencing the issue in a different implementation, please update the sample to reproduce the behavior, so we can investigate further - DockingTabDemo.zip
    P.S. Thank you for your suggestion @Wolfgang.
  • Posted 8 August 2025, 8:40 am EST
    That was it! Working now.
    Thanks for your assistance!
    Charlie
