C1Editor JavaScript Errors
Posted by: ckelly on 6 October 2017, 5:32 pm EST
    Posted 6 October 2017, 5:32 pm EST
    Is there anyway to suppress JavaScript errors in the C1Editor control? We are trying to have the control display in a mode above IE 7/8 using either a meta tag (<meta http-equiv=““X-UA-Compatible”” content=““IE=edge”” />) or through registry editing and receive JavaScript errors when either is used. Setting it back down to IE 8 values works, however the formatting is less than ideal for printing the documents.
    Here’s some simple VB.NET code to recreate the issue:
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Dim xmlDoc As New Xml.XmlDocument()
        xmlDoc.LoadXml("<html><meta http-equiv=""X-UA-Compatible"" content=""IE=edge"" /><body>test</body></html>")
        Dim c1 As New C1.Win.C1Editor.C1Editor
        c1.Dock = DockStyle.Fill
        c1.Document = xmlDoc
        Me.Controls.Add(c1)
    End Sub
    Thanks!
  • Posted 9 October 2017, 5:18 am EST
    I am discussing the case with the developers and would share their insights with you, once I receive them {Tracking ID: 290269}.
    Ruchir Agarwal
  • Posted 24 October 2017, 9:21 am EST
    We have received confirmation that this is a limitation. It is not possible to display the control in a mode above IE 7/8.
    Apologies for the inconvenience caused due to this.
    ~Ruchir Agarwal
