C1FlexChart rendering error when declaring RoundedLimits = true
Posted by: dung.itcdt on 29 March 2024, 6:01 am EST
  • Posted 29 March 2024, 6:01 am EST
    I am using C1FlexChart version 4.8.20233.631 and I am experiencing the following errors:
    • When I hover over the chart, the labels and major grid lines jump around.
    • When I enable animation and change the data source from data with large numbers to data with small numbers, the animation does not run completely and the values are not updated correctly until I hover over the chart multiple times.
    I have attached a video demonstrating the errors.
    Please fix this RoundedLimits bug as soon as possible.
    Thank you,
    Recording 2024-03-29 165234.zip
  • Posted 1 April 2024, 8:03 am EST
    We are sorry but we could not replicate the behavior you mentioned on our end by using the version you have mentioned.
    We created a chart with multiple LineSymbols series and applied a simple series animation to it. Please refer to the attached sample, FlexChart_RoundLimits_Animation_Test.zip.
    Could you please update the attached sample or provide us with a stripped-down sample of your project so that we can observe and investigate the behavior on our end?
    Uttkarsh.
