C1FlexDataTree with EF6 Code First
Posted by: loic.lucien on 5 August 2020, 4:14 am EST
    Posted 5 August 2020, 4:14 am EST
    I would like to use a C1FlexDataTree (like in the winforms DataTree.sln), but my project is EF6 code-first based. So I dont use direct SQL queries to manipulate my Entities.
    I have navigation properties on my entites (List related to Parent entity), and I try to display them using sub-level nodes,
    Is there a way to do this without DataSet relations configuration (because these relations already exists in my DbContext)?
    I don’t know if I’m clear.
    Thanks!
  • Posted 7 August 2020, 4:50 am EST
    to be more specific, I’m trying to use the existing relations between entites without redifining them with “DataSet.Relations.Add(DataSet.Tables[…”,
    Indeed, all relations between entites are already defined (code-first).
  • Posted 7 August 2020, 2:23 pm EST
    Can you please take a look at the CodeFirst product sample ‘Orders-EF-CodeFirst’ using C1DataSource. If this does not help, can you please share a stripped down application demonstrating your concern.
