C1FlexGrid columns not being added when backing DataSource is changed
Posted by: trevor.white on 13 November 2017, 2:00 pm EST
    Posted 13 November 2017, 2:00 pm EST
    All,
    I am having an issue with the C1FlexGrid columns not being automatically created when the backing DataSource object has changed.
    We were using v2.0.50727 and this behavior does exist and works, but in version 4.0.20172.271 this behavior does not exist.
    Is there a reason why new columns are not being created when the DataSource has changed (columns)? Is there something else that needs to be called in order for the C1FlexGrid to automatically create a new column in its collection?
    Thank You!
  • Posted 14 November 2017, 3:08 am EST
    We are unable to replicate the issue at our end . Please refer the attached sample.
    Could you please either modify the attached application or provide your own stripped down project so that we can try reproducing the same behavior at our end and assist you further accordingly?
    FlexGrid_DataSourceChanged.zip
