C1FlexGrid custom ColumnFilter which extends default filter
Posted by: wknauf on 20 May 2020, 6:03 am EST
    Posted 20 May 2020, 6:03 am EST - Updated 13 August 2025, 11:08 am EST
    Hi C1,
    a customer wants fo filter datetime values in a FlexGrid column by day of week. I found a way to reuse the existing datetime filter and extend it with a “Day of week” filter, see attached sample and screenshot:
    I did so by implementing a “IC1ColumnFilter” which encapsulates a “ColumnFilter” and also has additional properties for the weekday filter.
    In the UI, I added two radiobuttons to toggle beetween standard filter and weekday filter. Here comes the ugly part: in order to use the default filter control, I had to use reflection, because the type “ColumnFilterEditor” is internal:
          string strAssembly = typeof(IC1ColumnFilterEditor).Assembly.GetName().Name;
          Type typeColFilterEditor = Type.GetType("C1.Win.C1FlexGrid.ColumnFilterEditor," + strAssembly, true);
          IC1ColumnFilterEditor filterEditorDefault = (IC1ColumnFilterEditor) Activator.CreateInstance(typeColFilterEditor);
    But I don’t like this UI, because there are two places where you switch beetween filters:
    -my two radiobuttons
    -the buttons “Value filter”/“Conditional filter” in the standard filter.
    Is there any chance to extend/subclass the “ColumnFilterEditor” so that I can add a third toggle button “weekday” to the ToolStrip which shows my custom panel “day of week”?
    Probably this is a question for the developers, as the API would have to be enhanced.
    And please make “ColumnFilterEditor” a public class so I can instanciate it ;-).
    FlexFilterDateTime.zip
  • Posted 21 May 2020, 2:32 pm EST
    Hello Wolfgang,
    Thank you for sharing the application as well as describing the use-case in detail.
    However, as I understand, you are looking to add a Toggle button in the toolstrip of the Filter Editor Form. If that is the case, I would like to point out an approach that might be aware of. The approach is to access the filter editor form’s toolstrip at run-time and add the control then?
    Similar to following:```
    private void C1FlexGrid1_MouseDown(object sender, MouseEventArgs e)
    C1.Win.C1FlexGrid.HitTestInfo ht = c1FlexGrid1.HitTest(e.Location);
    if(ht.Type== C1.Win.C1FlexGrid.HitTestTypeEnum.FilterIcon)
    foreach (Form frm in Application.OpenForms)
    if (frm.Name == “FilterEditorForm” && frm.GetType().ToString() == “C1.Win.C1FlexGrid.FilterEditorForm”)
    ToolStripSplitButton weekdayFilter = new ToolStripSplitButton();
    weekdayFilter.Name = “_btnWeekdayFilter”;
    weekdayFilter.Text = “&Weekday Filter”;
    weekdayFilter.Click += WeekdayFilter_Click;
    (frm.Controls[0] as ToolStrip).Items.Add(weekdayFilter);
    Ruchir
  • Posted 23 May 2020, 9:06 am EST
    Hi Ruchir,
    actually, I thought about this approach too. But it seems too hacky for me and might break whenever you change the control, because the compiler does not tell me anything about this.
    Also, your sample stops at the interesting part ;-): I have to add my custom filter panel to it and toggle its visibility when my toolbar button or of the standard buttons is clicked. But this is no magic, just a bit of coding…
    Is it possible to make the “FilterEditorForm” class public, the toolbar and its buttons and the filter panels protected, so that I could subclass the form and add (by designer or by code) my custom controls?
  • Posted 26 May 2020, 6:07 am EST
    Thank you for sharing your concern using FilterEditorForm approach. So, I have now forwarded your request to the developers [ID: 438031].
    We will update this thread as soon as we receive some information.
    Ruchir
  • Posted 4 May 2021, 7:04 am EST
    any updates on this?
  • Posted 5 May 2021, 12:34 am EST
    We are getting in touch with the developers for the updates and will let you know soon.
  • Posted 14 September 2021, 4:16 am EST
    Any Update on this?
  • Posted 20 June 2022, 4:51 am EST
    Hi C1,
  • Posted 20 June 2022, 7:20 am EST
    Hello Wolfgang,
    Apologies for the delay in response.
    The last time when we checked the issue with the developers, it was there on their to-do list.
    I am getting in touch with them to get the ETA if any.
  • Posted 14 December 2022, 6:32 am EST - Updated 13 August 2025, 11:03 am EST
    As I found a change about column filters in the readme, I gave it another try. And I think my sample works much better now: in my “IC1ColumnFilterEditor” implementation, I can add the default “C1.Win.C1FlexGrid.ColumnFilterEditor” at design time instead of having to use reflection.
    Attached is an updated sample:
    FlexFilterDateTime_2022-12-14.zip
    There is also a sample “AdvancedFilters” which seems to be inspired by my original issue ;-): https://github.com/GrapeCity/ComponentOne-WinForms-Samples/tree/master/Core/FlexGrid/CS/FlexGridExplorer/Samples/AdvancedFilters
    But I will stay with my original approach to use two radio buttons to switch the filter mode, as the dropdown is very hidden. And never change running code ;-).
    Also, the “Avanced Filtering” sample seems to have a layout issue: the “Apply filter” button is hidden in the dropdown menu. Seems the filter popup is too small:
  • Posted 15 December 2022, 4:49 am EST - Updated 15 December 2022, 4:55 am EST
    Hello Wolfgang,
    We do agree that the filter popup is too small. Please find the attached sample with the dropdown in the filter form visible clearly.
    Also, we can see the Apply button in the "Advanced Filtering” sample, please see the attached screenshot for reference.
    This also looks nice. Thanks for sharing the sample :slight_smile:
    FlexGrid_QuickStart_Mod4.zip
  • Posted 15 December 2022, 6:57 am EST
    The missing “Apply” button might be related to my locale - the german texts are much longer than the english defaults.
  • Posted 16 December 2022, 1:36 am EST - Updated 16 December 2022, 1:41 am EST
    Hello Wolfgang,
    Yes, your understanding is correct, the apply button is hidden because the form width has less space.
    You can change the width of the filter form in the InheritedFilterEditorNewMenu file to get all the menu options in a single row.
  • Posted 16 December 2022, 4:18 am EST
    Thanks. For my implementation, that is not a problem, but I thought it might be helpful to fix the sample.
  • Posted 19 December 2022, 8:33 am EST
    Hello Wolfgang,
    We have raised this concern to the development team and will get it fixed soon.
