Posted 28 February 2020, 12:34 pm EST
Thank you all for your reply.
Prabhat,
.Free or .FixedOnly does not work when there are more than 2 rows to be merge. In my example, if I remove the top row, then it merge across correctly. It does merge correctly if the top row contain different text, but not when it is the same as the second rows. Can you check a 3 rows case like my sample?
I tested the custom merge example that you had replied to someone else in the past, and that works fine. I was hoping that the merge flag would work correctly as intended (based on my assumption). Also, thanks for always helping out with this forum, I’ve been a long time user, and have seen your post since way back when.
HL
