C1FlexGrid: Regression in .548: AutoSizeRows and wrapped text
Posted by: wknauf on 6 May 2022, 8:59 am EST
    Posted 6 May 2022, 8:59 am EST - Updated 13 August 2025, 11:12 am EST
    See attached samples (versions for .548 and .532, which both load grid data from xml file and call “AutoSizeRows”):
    SampleAutoSizeRows.zip
    When starting the .548 version (project “SampleAutoSizeRows” in solution), some cells are cut. In .532 this worked.
    Here is a screenshot for .532:
    And here is the screenshot for .548:
    This worked with .539. Maybe it is related to the fix for this issue https://www.grapecity.com/forums/winforms-edition/regression-in-c1flexgrid-5
  • Posted 6 May 2022, 8:59 am EST - Updated 13 August 2025, 11:12 am EST
    Better screenshot for .548, where the clipped cells are marked:
  • Posted 9 May 2022, 3:37 am EST
    Hi Wolfgang,
    We could see the issue at our end. We have reported it to the development team and will let you know as soon as we have an update.
    [C1WIN-27337]
    Kind Regards,
  • Posted 25 May 2022, 7:57 am EST
    Hi Wolfgang,
    We are happy to inform you that issue has been fixed in the latest 2022v1 hotfix release (4.5.20221.557). You can update to the latest version using the ComponentOne Control Panel or install the latest C1 packages using NuGet.
    https://www.nuget.org/packages/C1.Win.C1FlexGrid/
    Kind Regards,
  • Posted 27 May 2022, 7:04 am EST
    Thanks, I can confirm that it works now.
