C1FlexGrid StarWidth + ExtendLastCol + AutoSizeRows
Posted by: wknauf on 4 February 2019, 11:20 am EST
    Posted 4 February 2019, 11:20 am EST
    Hi C1,
    see attached sample: a grid is created with some columns. Three columns (among which is the last column) have a StarWidth. “ExtendLastCol” is set to “true”.
    When calling “AutoSizeRows” (this happens when the button is clicked), the last column loses the StarWidth and is now a fixed size column.
    This does not happen if “ExtendLastCol” = false.
    “ExtendLastCol” actually does not make sense here, but in our app, all grids inherit from a base class, and here ExtendLastCol is set to True.
    I would expect it to be ignored it “StarWidth” is set for any col.
  • Posted 5 February 2019, 7:59 am EST
    it seems that the sample is not attached properly. Could you please attach the sample again.
  • Posted 6 February 2019, 4:02 am EST
    Sorry, probably I forgot it :frowning:
    FlexStarWidth.zip
  • Posted 7 February 2019, 5:53 am EST
    Thanks for the application. I am able to replicate the issue with the latest build.
    I have escalated the issue to our development team(ID 366159) and will inform you once I get any information from them.
  • Posted 9 September 2019, 10:19 am EST
    We are happy to let you know that the issue you reported has been fixed in the latest release version. You can download the same from here: http://prerelease.componentone.com/hotfixes/dotnet/C1WinForms-452_4.5.20192.382.zip
    http://prerelease.componentone.com/hotfixes/dotnet/C1WinForms.4_4.0.20192.382.zip
    Also, would request you to kindly verify the fix.
    Ruchir
  • Posted 11 September 2019, 10:50 am EST
    Thanks, it works now!
