Posted 18 May 2020, 8:24 am EST
- Updated 3 October 2022, 11:54 pm EST
Dear Mohit,
I have joined the hole initial VB Code, As i told before. i have changed and added a Pie Chart. So the Question still the same :
1) How can i show the value on each Bar in the Chart?
2) How can i get each Bar having it’s own Color?
I have also joined one figure as result.
Private report As C1FlexReport
Private Function CreateChartSampleReport() As C1FlexReport
report = New C1FlexReport() With { _
.ReportName = “ChartSample” _
’ add data source “Employees”
Dim dsEmployees = New DataSource() With { _
.Name = “Employees”, _
.ConnectionString = “Provider=Microsoft.Jet.OLEDB.4.0;Data Source=…..\Reports\C1Nwind.mdb;Persist Security Info=False”, _
.DataSource = “Select * from Employees” _
report.DataSources.Add(dsEmployees)
’ add calculated field “FullName”.
Dim calcFullName = New CalculatedField(“FullName”, GetType(String), “=LastName & “” “” & FirstName”)
dsEmployees.CalculatedFields.Add(calcFullName)
’ add calculated field “Age”.
Dim calcAge = New CalculatedField(“Age”, GetType(Integer), “=Year(Now())-Year(BirthDate) + 1”)
dsEmployees.CalculatedFields.Add(calcAge)
’ add data source “Products”
Dim dsProducts = New DataSource() With { _
.Name = “Products”, _
.RecordSource = “Select Products.CategoryID as CategoryID, Categories.CategoryName as CategoryName, Products.UnitsInStock as UnitsInStock from Products inner join Categories on Products.CategoryID = Categories.CategoryID” _
report.DataSources.Add(dsProducts)
report.Sections.Header.Visible = True
’ add ChartField using Employees data source.
Dim sectionEmployees = report.Sections.Header.SubSections.Add()
sectionEmployees.Name = “ChartWithEmployees”
sectionEmployees.Height = 5200
sectionEmployees.Visible = True
sectionEmployees.Fields.Add(CreateChartForEmployees())
’ add ChartField using Products data source.
Dim sectionProducts = report.Sections.Header.SubSections.Add()
sectionProducts.Name = “ChartWithProducts”
sectionProducts.Height = 5200
sectionProducts.Visible = True
sectionProducts.Fields.Add(CreateChartForProducts())
Return report
End Function
Private Function CreateChartForEmployees() As ChartField
Dim chart = CreateChartField(“Chart1”, “Employees”)
chart.Header.Text = “Employees Age”
chart.ChartArea2D.Inverted = True
chart.ChartArea2D.AxisX.OnTop = True
Dim group = chart.ChartGroups2D.Group0
group.ChartType = Chart2DType.Bar
Dim data = group.ChartData
data.IsForEachRecord = True ’ show value of each record in data source
data.CategoryGroups.AddNewGroup(“=FullName”) ’ group by FullName
Dim seriesTemplate = data.SeriesValues.AddNewSeries()
seriesTemplate.DataValues.AddNewValue(“=Age”) ’ show Age in AxisY
Return chart
End Function
Private Function CreateChartForProducts() As ChartField
Dim chart = CreateChartField(“Chart2”, “Products”)
chart.Header.Text = “Sum of UnitsInStock by Category”
Dim categoryGroup = data.CategoryGroups.AddNewGroup(“=CategoryID”)
’ group by each CategoryID
categoryGroup.LabelExpression = “=CategoryName” ’ show the CategoryName in AxisX
seriesTemplate.DataValues.AddNewValue(“=Sum(UnitsInStock)”)
’ show sum of UnitsInStock in AxisY
Return chart
End Function
Private Function CreateChartField(name As String, datasource As String) As ChartField
Dim chart = New ChartField() With { _
.Name = name, _
.Width = 7500, _
.Height = 5000, _
.Top = 100, _
.Left = 100, _
.DataSource = datasource _
chart.Border.Color = Color.Black
chart.Border.Width = 15
chart.Border.Style = DashStyle.Solid
chart.Border.CornerRadius = New CornerRadius(200.0)
chart.ChartArea2D.AxisY.AutoMin = False
Return chart
End Function
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
C1FlexViewer1.DocumentSource = report
End Sub
Said
