C1FlexViewer on windows 2008 R2/Windows 7
Posted by: mysql.jorge on 15 June 2020, 4:55 pm EST
    Posted 15 June 2020, 4:55 pm EST
    Howdy,
    I have some need’s to open the app on windows 2008 r2 or windows 7, and the flexviewer that i have setup to display pdf files.
    On these environments, i have the error bellow.
    Is it the lack of some support/framework/whatever that i need to install, or this OS’s are really not supported anymore?
    thanks in advanced,
    System.InvalidCastException: Specified cast is not valid.
    at C1.Util.DX.ComObject.QueryInterface(Guid guid, IntPtr& outPtr)
    at C1.Util.DX.ComObject.QueryInterfaceT
    at C1.Win.C1Document.Util.C1DXTextLayout…ctor(IC1DXTextLayoutOwner owner)
    at C1.Win.C1Document.Util.C1DXTextMeasurementContext…ctor()
    at C1.Win.C1Document.C1TextSearchManager…ctor(C1DocumentSource documentSource)
    at C1.Win.FlexViewer.C1FlexViewerPane.#fvn()
    at C1.Win.FlexViewer.C1FlexViewerPane.#Hun()
    at C1.Win.FlexViewer.C1FlexViewerPane.#Eun(C1DocumentSource #Fun)
    at C1.Win.FlexViewer.C1FlexViewerPane.set_DocumentSource(C1DocumentSource value)
    at C1.Win.FlexViewer.C1FlexViewer.set_DocumentSource(C1DocumentSource value)
    at Decimal_Correspondencia.frmviewer.frmviewer_Load(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at C1.Win.C1Ribbon.C1RibbonForm.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
  • Posted 16 June 2020, 6:49 am EST
    Hi Jorge,
    The minimal system requirements for using the FlexViewer is given in the link below:
    https://www.grapecity.com/componentone/docs/win/online-flexreport/overview.html
    Please make sure you are using the appropriate OS version.
    If you still get the issue at your end, share the report with dummy data that is causing an error so that we can replicate the same issue at our end and assist you accordingly.
  • Posted 16 June 2020, 3:13 pm EST
    Ok thanks, solved!
