C1InputPanel...Any way to include a multiselect-capable list?
Posted by: jwhitney on 14 June 2018, 11:17 am EST
    Posted 14 June 2018, 11:17 am EST
    I don’t see C1MultiSelect as a component option to add to a C1InputPanel. Is there any way to have any type of multi-select list component in a InputPanel?
  • Posted 15 June 2018, 4:53 am EST
    Hi jwhitney,
    In order to use a C1MultiSelect inside a C1InputPanel you need to define a class that inherits from the InputControlHost class and then invoke the desired control’s constructor, like this:
    public class C1MultiSelectForInputPanel : C1.Win.C1InputPanel.InputControlHost
    public C1MultiSelectForInputPanel()
    : base(new C1.Win.Input.C1MultiSelect())
    Now, you can access the C1MultiSelect properties from an C1MultiSelectForInputPanel object by using the Control property and then cast like this:
    var cntl = (C1MultiSelect)c1MultiSelectForInputPanel1.Control;
    I’ve created a simple example that demonstrates how to place C1MultiSelect inside C1InputPanel for multiple selection.
    +Manindra
    InputPanelMultiSelect.zip
  • Posted 15 June 2018, 6:31 am EST
    Thanks Manindra.
  • Posted 18 June 2018, 5:25 pm EST
    Thanks for the solution!
