Posted 25 April 2018, 8:57 am EST
I am using C1InputPanel with several C1InputPanel.InputNumericBox’s. I have set the minimum and maximum properties for these boxes. If the underlying dataset has a value outside of the range the recordset is not displayed. It does not throw an error it just won’t go there. Is there an event, method or property I can use to flag the field, skip the field, notify the user, bypass the record…?
