C1Olap WinForms subtotal column
Posted by: info on 13 February 2018, 7:02 am EST
    Posted 13 February 2018, 7:02 am EST
    I am evaluating C1Olap for WinForms. How can in OlapFlexGrid CellChanged event reference a SubTotal column, in order to dynamically change the cell backcolor based on cell content/value?
    Is it possible to achieve this programmatically?
    There is another way than CellChanged event?
    Thanks!
  • Posted 14 February 2018, 7:52 am EST
    Thank you for showing interest in using our controls.
    Before, I proceed with helping you meet your requirement. I would like to inform you that we have another control named FlexPivot, which is an enhanced version of C1Olap and includes more advanced feature. Therefore, I suggest you to once review that control too.
    Here is the documentation link for the same: http://help.grapecity.com/componentone/NetHelp/c1flexpivot/webframe.html#FlexPivotOverview.html
    I would also suggest you to refer following link:
    https://www.grapecity.com/en/forums/winforms-edition/olap-vs--flexpivot
    Regarding your requirement of customizing the appearance of cells conditionally, we suggest you to rather use OwnerDrawCell event, which fires before a grid cell is drawn.
    I have attached a demo application to show its implementation and also attached an image showing the output observed using it.
    *The suggested approach works for the new control FlexPivot too. Let me know, if you need a sample in FlexPivot too.
    Ruchir Agarwal
    ConditionalFormatting_C1Olap.zip
  • Posted 14 February 2018, 1:49 pm EST
    Hi Ruchir,
    Thank you very much, this is a great solution.
    For me it would be easier to identify the column with its name instead of its index.
    I tried c1OlapPage1.OlapGrid.Cols[44].Caption); and I get the caption, while with
    c1OlapPage1.OlapGrid.Cols[44].Name); I get a string “Freight:0;{total}”, not a single column name (or field name). it’s a strange thing, in my opinion.
    Kind Regards,
    Silvano Rinaudo
  • Posted 15 February 2018, 1:53 am EST
    Hi Silvano,
    The Name of the aggregate column you are observing makes sense because ‘Freight’ column(the one having index:44) is actually a sub-column of ‘Total’ column hence ‘Freight:0;{total}’ is returned for Name of the column. Also, ‘Freight’ column exists for all the countries too and since we need a unique name for every column, we follow this naming convention for the subset columns
    To workaround this, you could use something like following:```
    if (c1OlapPage1.OlapGrid.Cols[e.Col].Caption==“Total” && Convert.ToString(c1OlapPage1.OlapGrid[1,e.Col])==yourColName&& e.Row >1)
    // same code for customizing this column’s UI
    Ruchir Agarwal
  • Posted 16 February 2018, 9:36 am EST
    Hi Ruchir,
    now it’s all clear, thanks again.
    Silvano Rinaudo
