C1PrintDocument to Memory Stream as MailMessage Attachment
Posted by: mikemacguyver on 31 May 2019, 12:00 pm EST
    Posted 31 May 2019, 12:00 pm EST
    Attempted to attach a c1printdocumment to a mail message via a memory stream.
    The pdf comes across three and half times the size of the actual document if exported to a file.
    When attempting to open the document it states it’s corrupted.
    What can be done to correct this issue?
    Mike
    Code:
    Public Sub EmailReg(ByVal recipient As String, ByVal sender As String, doc As C1PrintDocument)
    Try
    Using client As New SmtpClient
    Using email As New MailMessage
    email.From = New MailAddress(sender)
                    email.To.Add(New MailAddress("myemail@mybusiness.com"))
                    email.Subject = "Registration Code"
                    email.Body = "Please review the attached document For a registration code."
                    Using ms As New System.IO.MemoryStream
                        Dim provider = New C1.C1Preview.Export.PdfExportProvider()
                        ms.Position = 0
                        doc.Export(ms, provider)
                        email.Attachments.Add(New Attachment(ms, "Registration.PDF", "application/pdf"))
                        client.Host = "mail.mybusiness.com"
                        client.Port = 25
                        client.Send(email)
                    End Using
                End Using
            End Using
        Catch ex As Exception
            SendErrorEmail(ex.ToString())
        End Try
    End Sub
  • Posted 31 May 2019, 2:35 pm EST
    Fixed it!
        Try
                    email.To.Add(New MailAddress("email@mybusiness.com"))
                        ms.Position = 0
                        email.Attachments.Add(New Attachment(New MemoryStream(ms.ToArray), "Registration.PDF"))
                        client.Port = 25
                        client.Send(email)
                    End Using
                End Using
            End Using
        End Try
    End Sub
