Posted 16 July 2018, 8:17 am EST
on Windows 10 the .Document property of PrintPreview Control is Nothing and could not be used for setting the Document of generated Report.
Product version 4.6.20133.54703
Posted by: m.routchkan on 16 July 2018, 8:17 am EST
Posted 17 July 2018, 2:05 am EST
I used the attached sample with 4.6.20133.54703 builds and no issue was observed. C1PrintPreviewcontrol’s Document property worked fine and showed the report as expected.
Could you please explain the issue in more detail so that we can assist you further?
prj_C1Report.zip
Posted 25 July 2018, 8:59 am EST
Thank you, I have found my mistake.
Unfortunately the loading of external xml Report is very slow under Windows 10, but it is another topic.
Posted 26 July 2018, 2:01 am EST
I tried with a simple xml report, as in the attached sample but could not observe the issue. The report rendered smoothly without delay, on a Windows 10 machine. Can you share your report with me? I would like to investigate this and assist you further.
C1Report_Rendering.zip
