C1Report: Barcode
Posted by: topran on 19 December 2017, 8:41 am EST
    Posted 19 December 2017, 8:41 am EST
    I’m using a Barcodefield (Code 39) in a report build with C1ReportsDesigner.
    Every time I generate a Barcode, e.g. ABCD the result is ABCD9.
    How can I prevent the 9 at the end of the barcode?
    Hier is the snippet from the report:
    BarcodeField
    0
    ArtikelNr2
    -1
    5
    5445
    11460
    3000
    720
    Best regards,
    Thomas
  • Posted 20 December 2017, 12:49 am EST
    Hello Thomas,
    Thanks for the sample code. We could observe that 5 that you have used is for Code93. For Code39, 3 is used.
    However, we could not replicate the issue with any of the barcodes mentioned above.
    A sample report has been attached for your reference. Kindly modify the same to replicate the issue and share it back. This will help us assist you further.
    test.zip
