C1Report | Export To Excel
Posted by: chandra.shekhar on 16 June 2020, 11:02 am EST
    Posted 16 June 2020, 11:02 am EST
    While exporting report into excel format we are getting below error when we added more then 2 children in Body by using (printDoc.Body.Children.Add) method, how ever same thing is working fine in case of pdf
    Can not resolve reference with code [3] while add object to the [RenderFragmentCollection] list. (c1d version: 2.7). A newer version of C1.C1Preview.2 assembly is required (4.6.20141.54717 or later). Please check ComponentOne site (http://www.componentone.com) for updates. —> System.Exception: Can not resolve reference with code [3] while add object to the [RenderFragmentCollection] list.
  • Posted 17 June 2020, 6:09 am EST
    It is very strange and we never came across this kind of issue before.
    As you are using the very old version of the control i.e. 2014 builds and we do not provide support to this much older version so you are requested to check the behavior with the latest builds i.e. 20201.416 that you can download from the given link:
    If the issue still exists at your end then you are requested to share a stripped-down sample of your application with the steps to replicate the issue so that we can replicate the same issue at our end and assist you accordingly.
