C1report - not print zero value
Posted by: massimo.valtolina on 30 March 2020, 12:12 pm EST
    Posted 30 March 2020, 12:12 pm EST
    Is it possibile do not print a number if it’s zero ?
    At the moment, using format, i have 0,00
    Thanks in advance
  • Posted 31 March 2020, 2:04 am EST
    Hi Massimo,
    You can use the script to hide the record that has 0 as a value in the OnPoint property of the detail section.
    If you using a report by code then you can use the PrintSection event to do the same. As done in the attached sample, please have a look.
    C1ReportDemo.zip
  • Posted 4 April 2020, 1:24 pm EST
    Thanks Prabhat Sharma
