C1Report Parameters Filter SQL Data
Posted by: eduardo.cardia on 9 March 2023, 5:07 pm EST
    Posted 9 March 2023, 5:07 pm EST
    Hi!
    Im my Sql Table there are a columm with the informations RJ , SP, PR … per line of register and others columms with another information.
    I need to create a paremeter to filter three condicions:
    1 - All the registers (parameter blank maybe)
    2 - Only one information - examplo “RJ”.
    3 - More than one information as (“RJ”,“SP”,“PR”) IN(,)… maybe too.
    By SQL Select Where or VBscript. Could anybody help me?
    Tks
    Cardia
  • Posted 10 March 2023, 8:04 am EST
    Hello Eduardo,
    The C1Report has been a legacy product and has been in maintenance mode for a very long time. There is no direct way to create a multi-value parameter in C1Report but you can check out the following blog to see how you can create a custom parameter and achieve your requirement:
    https://www.grapecity.com/blogs/custom-parameter-dialog-in-c1reports
    FlexReport is the new flag-shipped report control, and you can easily create multi-value parameters using it. Please see the following doc link for the same:
    https://www.grapecity.com/componentone/docs/win/online-flexreport/Multi-valueParameters.html
    You can check out the “MultiValue DataBound Parameters” report in the FlexCommonTasks.flxr at the following location of your machine.
    …\Documents\ComponentOne Samples\WinForms\v4.5.2\FlexReport\CS\FlexCommonTasks
