C1Schedule : indexmapping sequence
Posted by: fsegui on 27 September 2021, 8:34 am EST
    Posted 27 September 2021, 8:34 am EST
    I’m using C1Schedule linked to a database.
    Appointments are mapped with IndexMapping (integer).
    I’m having an issue with index sequence.
    For example, the last index in database is 856. The event with 856 is then deleted by a user but not directly in the schedule.
    Then the user adds an appointment using the C1Schedule, the appointment is well added in the database with index 857. But if I try to open it, the key returned by C1Schedule is 856.
    Is there a way to refresh the sequence in C1Schedule ?
  • Posted 28 September 2021, 4:56 am EST
    Could you please share a sample with a dummy database(.mdb file )? It will really help us investigate the situation at our end and help you better.
    Are you deleting the event in the database or the DataTable? If you are changing anything in the data table then the changes should reflect in the C1Schedule and it should work accordingly.
    Avnish
  • Posted 29 September 2021, 5:33 am EST
    Actually, when I tried to set up a dummy sample, I’ve seen that update/delete commands for my table adapter where still referencing an old database name.
    Now it works fine.
  • Posted 30 September 2021, 4:42 am EST
    Good to hear that your issue has been resolved.
    Regards.
    Avnish
