Posted 18 July 2019, 3:06 am EST
C1Schedule does not export the Reminder information to the separate fields.
In the AppointmentMappingCollection you can find the “AppointmentProperties” property. It allows the other properties of the Appointment object like Reminder information to be bound to the appropriate field in the data source.
In the appointments table, you should create a field ‘Properties’ which should be mapped to “AppointmentProperties” property of AppointmentMappingCollection. This field is a collection of many appointment properties including Reminder, in XML form.
For more information, you can refer to the product sample named “C1ScheduleDemo” and check it’s Appointment mapping table and respective field in the Appointments table of C1NWind database.
You can find the product sample and C1NWind database in your system at the given locations respectively :
…\Documents\ComponentOne Samples\WinForms\C1Schedule\CS
…\Documents\ComponentOne Samples\Common
Kindly refer to the following link for more information :
https://help.grapecity.com/componentone/NetHelp/c1schedule/webframe.html#C1.Win.C1Schedule.4~C1.C1Schedule.AppointmentMappingCollection_properties.html
Thanks and Regards,
Prabhat Sharma
