C1SplitButton: Crash if UIAutomation is enabled
Posted by: wknauf on 6 September 2024, 9:21 am EST
    Posted 6 September 2024, 9:21 am EST
    Hi C1,
    C1SplitButton crashes if a UIAutomation provider is enabled (e.g. caused by windows screen narrator, might also happen in RDP/Citrix sessions):
    Exception-Type: System.InvalidCastException
    Message: Unable to cast object of type 'C1.Win.Input.SplitButtonItem' to type 'C1.Win.Input.C1SplitButton'.
    StackTrace:
       at i.a()
       at i..ctor(bd a, dm b)
       at bd.bc()
       at fv.get_b()
       at cm..ctor(dm a, C1SplitButton b)
       at dm.ck()
       at fw.get_b()
       at fw.WndProc(Message& a)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, WM msg, IntPtr wparam, IntPtr lparam)
    Attached sample reproduces it:
    step 1: start windows screen narrator
    step 2: start the sample, drop down the split button and hover over the items. I have a global “unhandled exception” handler which shows a messagebox.
    SplitButtonTest.zip
    Some time ago, a similar problem happened with C1FlexGrid: https://developer.mescius.com/forums/winforms-edition/c1flexgrid-crash-raiseautomationevent-value-cannot-be-null
    But I cannot apply the workaround to override WndProc and ignore event “61”. My sample already contains a C1SplitButton subclass, but the issue still happens. Do you have any idea?
  • Posted 7 September 2024, 12:06 pm EST
    It happens only when hovering over items that have child items.
    Workaround to avoid the crash: override “WndProc” in e.g. the form that contains the C1SplitButton. If the message “WM_GETOBJECT” is received, then hide all drop down items that contain child items. Of course this means that part of the functionality is lost.
    protected override void WndProc(ref Message m)
      //WM_GETOBJECT = 61 = 0x003D
      if (m.Msg == 61)
        //...Hide all items with children
    Hopefully, C1 has an idea for a better workaround.
  • Posted 9 September 2024, 5:19 am EST
    Hello Wolfgang,
    Thank you for providing the details. We were able to observe the behavior as well.
    We have escalated it to the development team for their insights. Rest assured, we’ll update once we have more information.
    [Internal tracking ID: C1WIN-32912]
    Uttkarsh.
  • Posted 23 September 2024, 7:52 am EST
    Hello Wolfgang,
    As per the development team, the reported behavior is a bug.
    [Bug tracking ID: C1WIN-32976]
    Unfortunately, currently we neither have a workaround for this nor an ETA for the fix. Rest assured, we’ll update you once the issue’s fixed.
    Uttkarsh.
  • Posted 28 October 2024, 7:57 am EST
    Just asking for an update: Is there a schedule for the fix?
  • Posted 29 October 2024, 7:41 am EST
    Hello Wolfgang,
    We’re getting in touch with the team to get an update on the schedule for the fix? We’ll get back to you once we have more information.
    Uttkarsh.
  • Posted 8 November 2024, 5:19 am EST
    Hello Wolfgang,
    As per the team, since this issue was reported between July and November, it will be fixed after the 2024v2 release, on the following Hotfixes.
    Uttkarsh.
  • Posted 13 June 2025, 3:20 am EST
    Do you have a schedule for this fix?
  • Posted 15 June 2025, 11:52 pm EST
    Hello Wolfgang,
    The issue has been fixed in the latest 2025v1 release. Please update the version of C1 to resolve the issue.
    Uttkarsh.
  • Posted 16 June 2025, 5:05 am EST
    I can confirm that the crash does not happen with .709. Unfortunately, we cannot upgrade to this version due to problems in C1FlexReport.
