C1Splitcontainer Windows 10
Posted by: grapecity on 28 April 2018, 1:54 am EST
    Posted 28 April 2018, 1:54 am EST
    I use C1Spiltcontainer (4.0.20181.303) for a long time and all works under W7 and W10.
    But since a short time - I guess after a Windows 10- Update - I have a problem.
    I use the C1SpiltContainer on tabpages - I have 8t abpages each with splitcontainer.
    Now only the Splitcontainer of the first tabpage and the first shown tabpage are visible.
    All other container are not visible.
    It is also not possible fpor me to change the visible-Property to true.
    With windows 7 it works still perfect.
    Do you have an idea?
    Thanks Horst
  • Posted 30 April 2018, 2:45 am EST
    Hello Horst,
    I tried replicating the issue but no such problem occured at my end. I tried with Win10 Version 1709 (OS build: 16299.309) + VS17 environment using the same C1 build version as yours. Please try running the attached application at your end and see if it works.
    Also, I understand that the issue might be related to Win10 version, as you mentioned. So, could you please share the OS version you are running the application in and where the issue has been observed.
    Also, please clarify whether you are using C1DockingTab or MS-Tab to contain the C1SplitContainer(s).
    Ruchir Agarwalprj_C1SplitContainer.zip
