c1SsrsDocumentSource [ERROR]: Invalid RplSize: [12 pt]
Posted by: adrian on 7 January 2018, 7:10 am EST
    Posted 7 January 2018, 7:10 am EST
    I’m trying out the SSRS Report Viewer sample and am getting the above error on one of my reports. Using SQL Server 2016, the report runs fine using the SSRS web portal but fails when run in the sample. I have other reports that work ok but this one fails. Any ideas?
  • Posted 8 January 2018, 11:57 pm EST
    Hello Adrian,
    Please check if the report has font size for any text set to 12 pt. If yes, kindly reduce the same to a lower value and see if the issue persists with the viewer.
    Also, kindly share the report with us. This would help us analyse the issue and escalate it to the concerned team.
  • Posted 11 January 2018, 7:12 am EST
    I think I’ve tracked it down. in my report I have an expression that sets the font size of some text
    iif(Fields!AttributeName.Value=“Device Name”,“12 pt”,“8 pt”)
    This works fine in Reportbuilder and SSRS web portal, SSRS ReportViewer etc. but fails with the above error using c1SsrsDocumentSource. The issue is with the space in “12 pt” and “8 pt”. If I remove the space then all is well.
    So, is it possible to have c1SsrsDocumentSource updated to allow the space?
  • Posted 12 January 2018, 4:56 am EST
    Hello Adrian,
    We are discussing this internally (Internal Tracking ID: 304904). Will get back to you once we are done.
  • Posted 13 March 2018, 3:23 am EST
    Hello Adrian,
    The issue has been fixed with the latest 2018 v1 builds.
    You can use C1Live to upgrade to the same.
