C1SuperTooltip doesnt popup anymore after contextmenu click
Posted by: Ranba790 on 22 March 2018, 7:27 am EST
    Posted 22 March 2018, 7:27 am EST
    When the C1SuperTooltip popup on a control and then you right click on the control with a ContextMenu(while the tool tip is showing up) after that the C1SuperTooltip will not popup anymore.
    If you change the ContextMenu to ContextMenuStrip it will work ok
    Any idea how to fix it beside replacing the ContextMenu to a ContextMenuStrip
  • Posted 23 March 2018, 2:39 am EST
    Hi Ran!
    As a workaround, you can manually show C1SuperTooltip after the context menu has been collapsed in MouseEnter event handler of the control (say, TextBox).
    bool _flag = true;
    private void TextBox1_MouseEnter(object sender, EventArgs e)
           if(_flag)
                 c1SuperTooltip1.Show(*TipText*, textBox1);
    private void ContextMenu1_Popup(object sender, EventArgs e)
            _flag = false;
    private void ContextMenu1_Collapse(object sender, EventArgs e)
            _flag = true;
    Also, I am reporting this issue with ContextMenu to the concerned team [Internal Id : 315352]. I will let you know once it is fixed.
    Best regards,
    Meenakshi
  • Posted 23 March 2018, 7:03 am EST
    Thank you
  • Posted 24 April 2018, 11:23 pm EST
    Hi Ran,
    As per the team, this is a limitation with ContextMenu.
    • Meenakshi
