Posted 25 October 2017, 6:58 am EST
Hi Peter!
Please make sure that the hotfix assemblies are unblocked before you use them in your application. To know how to unblock them, you can see solution 1 on the given link:
https://www.grapecity.com/en/blogs/a-step-ahead-troubleshooting-common-errors-part-i/
Kindly follow the given steps, in order to use hotfix:
- Expand the References node in the solution explorer.
- Replace the existing C1 assemblies with the corresponding hotfix assemblies.
[ To replace the assemblies follow these steps:
a. Delete the existing assembly from the project.
b. Right click on the References node and click on ‘Add References’.
c. In Reference Manager, Click on the Browse button. And, browse to the local location of hotfix assemblies.
d. Select the assemblies and add. ]
- Close all the Form designers of the project.
- Open Licenses.licx, and remove everything after assembly name. Now, it looks like ‘C1.Win.C1Input.C1TextBox, C1.Win.C1Input.4’.
- Clean and Rebuild the solution.
Hope this helps you. In case, you still face any issue with this then let me know, along with the screenshot.
Meenakshi
