C1TextBox + C1DateEdit stuck in Enabled = false mode in TabControl
Posted by: abraham on 1 May 2025, 3:53 am EST
  • Posted 1 May 2025, 3:53 am EST
    At about 40% of doing a full LOB migration project we ran into an interesting bug for both the C1TextBox and C1DateEdit (and possibly other C1 controls as well) which has caused the migration to be paused again.
    Please find enclosed a VS 2022 solution that demos the bug. The Form shows instructions on how to reproduce it.
    This bug seems to occur under the following conditions:
    • C1TextBox or C1DateEdit (both part of a TabPage) are bound to a BindingSource which in turn has the DataSource set to a DataView for which any RowFilter changes will determine whether the DataView has any available DataRowView objects or not.
    • as long as the BindingSource and its connected DataView has rows available - the C1 controls behave just fine.
    • when a DataView RowFilter update causes the DataView to be empty, the C1 controls automatically switch to ‘Enabled=false’ mode as soon as the TabPage that hosts them is activated.
    • but even when the DataView RowFilter is changed/de-activated and the DataView has rows available again; the C1 controls remain stuck in Enabled = false mode, and cannot be edited anymore (although data is being displayed). The C1 controls become read-only incorrectly.
    • please observe the standard .NET TextBox and CheckBox show the correct behaviour
    I’ve included the same DataTable columns with identical .NET and C1 controls so the difference in behaviour can be observed clearly. The lock-up of the C1TextBox and C1DateEdit controls in Enabled = false mode is clearly a bug.
    We discovered this bug as one of our complex forms that uses a similar config worked fine in .NET 4.8 yet locked-up in the migrated .NET 9 project.
    At the moment we can’t continue with our migration so a fix is greatly appreciated.
  • Posted 1 May 2025, 3:55 am EST - Updated 1 May 2025, 8:13 pm EST
    C1 Input Enabled Bug Demo.zip
    Forgot to mention this is about the latest version of the C1 Input controls (8.x) and .NET 9
  • Posted 2 May 2025, 6:52 am EST
    Thanks a lot for sharing the sample project and complete details. We could see the behavior you mentioned. We have reported it to the development team for further investigation and will let you know the updates as soon as possible.
    [Internal Tracking ID: C1WIN-34001]
  • Posted 14 May 2025, 1:14 am EST
    The development team has confirmed that this is a bug. The ETA for the fix is the 2025v1 Hotfix 1 release.
    [Bug tracking ID: C1WIN-34033]
  • Posted 22 May 2025, 3:25 am EST
    Is there an ETA for the 2025v1 Hotfix 1 release? I noticed there was a hotfix for 2024v2 a couple of days ago.
  • Posted 23 May 2025, 12:12 am EST
    A fixed release date for the 2025v1 Hotfix 1 has not been decided yet, but it is expected to be available around mid of July.
    Thank you for your patience.
