C1TreeView for WinForms | C1TreeColumn - DisplayFieldName Property
Posted by: yonit.chavshosh on 29 January 2019, 3:45 am EST
    Posted 29 January 2019, 3:45 am EST
    I have recursive list. each node includes an object with some properties that are part of the node.
    I want to view these properties as they are the node’s property, not in a sub node .
    For example :
    List=new List();
    Class Shape
    string Name;
    int NumOfRibs;
    Point CenterPoint;
    List Descendents;
    public Shape()
    Descendents=new List();
    Class Point
    int X;
    int Y;
    I want X and Y to be in the Row of Shape
    What I have to write in DisplayFieldName of their columns?
    Yonit
  • Posted 30 January 2019, 7:40 am EST
    Hello Yoni,
    As per my understanding, you want to show the data in Hierarchical way. To achieve the same you can refer to the following documentation link:
    https://help.grapecity.com/componentone/NetHelp/treeviewwin/webframe.html#BindingTreeViewtoHierarchicalData.html
    Also, you can refer to the product sample located at “C:\Users\MohitG\Documents\ComponentOne Samples\WinForms\C1TreeView\CS\BoundModeWithBindingList”
    If I am missing something, could you please explain in detail.
  • Posted 31 January 2019, 3:50 am EST
    Thanks for replying,
    But my problem is that I want to view Point not as Hierarchical Data but as part of my data
    and the descendents shapes are Hierarchical Data.
    how can I do that property of Point will be viewed in the same row of shape properties.
    like that,
    each shape node will has these columns:
    Name |NumOfRibs |center X| center Y
    and the descendents shapes will be nodes of this node.
    Name and NumOfRibs are simple to do
    C1TreeColumn c= new C1TreeColumn {
    HeaderText="Name "
    DisplayFieldName="Name "
    but how I can I set ‘Center X’ column??
    It is not a property of shape
    It is a property of Point that is included in Shape.
    Thanks for help,
    Yonit
  • Posted 1 February 2019, 5:37 am EST
    Hello Yoni,
    Could you please try after setting the following property:
    HeaderText="center X"
    DisplayFieldName="\\\\X"
    Same thing is implemented in the prvious recommned sample(BoundModeWithBindingList). You, could also refer to it.
