C1TrueDBGird: change the FilterDefinition via VB-Code
Posted by: s.wortmann on 13 May 2022, 2:06 am EST
    Posted 13 May 2022, 2:06 am EST
    Hello together.
    I would like to know how to edit the FilterDefinition of the C1TrueDBGrid via VB code.
    Example:
    Columns A, C,D and F are filtered.
    C1TrueDBGrid.Splits(0).FilterDefinition can be retrieved and should now be changed via VB code:
    The filter for column D should be removed and an additional filter should be added for column H. So that as a result column A,C,F and H are filtered.
    I hope I have not described too complicated and someone can give me tips.
    Thank you very much.
  • Posted 16 May 2022, 4:55 am EST
    Hi together,
    No more help is needed as I figured it out myself.
    I solved it with the XML functions from the Net framework.
    Stephan
  • Posted 16 May 2022, 7:45 am EST
    Hi Stephan,
    Good to hear that your requirement is fulfilled. Please let us know if you face any other issues or if you need any other information.
    Kind Regards,
